September 24, 2017, 10:44:09 PM *
Author Topic: Changing tires on the XR650L  (Read 597 times)
« on: November 02, 2015, 08:47:26 AM »
This past Saturday I had set myself an ambitious project - changing the XR650L knobbies (death cornering!) for some more street friendly Avon Trailriders front and back. I had employed the services of Anders to keep me right in technique and in case I couldnt do it  Cool. Plus I was testing out my recently purchased trail stand that is necessary since the XR dosent have a center stand.
Trail stand works as advertised allowing for both front and back wheels to be removed
After many breaks, lots of sweating and muscling on my part and nearly 2 1/2 hrs later...
New tires warming in the sun to make it easier to get them on - it helped a lot!
The front
Trail stand lifting the rear and front
The front wheel required more inflates/deflates to get the tire to seat properly - part of issue was the tires were tubless so tighter sidewalls - eventually we went to the gas station and got it up to 102 psi  Cool
The final result - corners sooooo much better!
Points to note:
1. KTM tire irons are superior to anything I had - which were two long motion pro tire irons and two short ones. The KTM ones have the right ends and it makes it much easier. 3 irons make it easier.
2. Getting the valve back in the rim defeated me this time - looking at getting a valve stem puller to help out here
3. Getting the new tire on was easier in the front. The final bit requires some strength and I discovered that I need more strength  Cool
4. Right now I could probably patch a tube in the wilds but probably couldnt change a tire yet - need more practice!
The CB750K4 sunning itself waiting for a ride
« Last Edit: November 02, 2015, 08:49:54 AM by andy750 » Logged
« Reply #1 on: November 02, 2015, 01:34:21 PM »
Nice work.  Changing tires with tire irons is a bastard.  Tried it once, that was enough.
« Reply #2 on: November 02, 2015, 01:45:56 PM »
Yes its tough. My arms are rather tired this morning. I rode the bike to work this morning - brraaap! Was a lot of fun and wow what a difference on the corners. Was going a fair clip on I-95 (at 7am  Cool) and bike held stable - though obviously not as planted as the VStrom. Not sure Id want to do it for extended hours at that speed though.
« Reply #3 on: November 03, 2015, 10:13:04 AM »
The real test will be to take it on some dirt now.  See if the street tires are capable.
« Reply #4 on: November 03, 2015, 02:37:29 PM »
Very true. These Trailriders have some deep grooves so I think they will have decent traction. For my kind of trails (fire roads, trails etc) I think they should be fine.
