June 24, 2017, 04:45:54 AM *
Pages: [1] 2
Author Topic: Dot 3, Dot 4, Dot 5 or Dot 3/4  (Read 1797 times)
« on: May 14, 2014, 11:53:41 AM »
After reading about it a bit, I think I will go with Dot 3 fluid. What are you using and why? There is a Valvoline Dot 3 and 4 fluid I am considering buying. Why shouldn't I? - http://shop.advanceautoparts.com/p/valvoline-dot-3-and-4-synthetic-brake-fluid-12-oz.-601457/89016680-P?searchTerm=dot+4
« Reply #1 on: May 14, 2014, 01:40:13 PM »
I use Dot 3.  I use dot 3 because that's what the manual says, i would have replace all the hoses etc if i switched, and because Anders said so.
« Reply #2 on: May 14, 2014, 01:48:24 PM »
Thanks. Since I am replacing everything but the master cylinder, I will use that Dot 3/4 Valvoline fluid. Somebody stop me before it's too late!
« Reply #3 on: May 14, 2014, 05:56:27 PM »
The manual says that because DOT 4 hadn't been invented yet.
Just do't use DOT 5, with anything that's had DOT 3 or 4 in it, and you'll be fine.
« Reply #4 on: May 14, 2014, 06:38:53 PM »
That was my take on the whole thing also. However, they didn't have that 3/4 stuff in the store, so I just got the dot 3
Thanks!
« Reply #5 on: May 14, 2014, 09:47:35 PM »
+1
« Reply #6 on: May 14, 2014, 10:16:42 PM »
And whatever you do dont ever ever use DOT 6!!! Unless you want to meet the Corona Girls  and end up with a compromising tattoo and end up working for Follywood  Grin Cool
« Reply #7 on: May 14, 2014, 10:22:11 PM »
DOT 6 it is then!!!
mick750F
« Reply #8 on: May 20, 2014, 05:35:18 PM »
   C'mon now Andy, you love my tattoo. Jealous you are...
   Stick with the dot 3 or 4 Peter. I once went to silicone and it was a pain to go back to non. Some say that you can't but I haven't had a problem after multiple flushings of the system.
« Reply #9 on: June 16, 2014, 07:42:55 AM »
So no one accuses me of not following up…
I rebuilt my front calipers and rear drums on my '70 MG a couple weeks ago. Having no idea what brake fluid was in there, and the fact that I replaced all the wet parts, and at least 80% of the brake lines, I figured, flush out the old and replace with DOT 5. Here is the bottle I flushed into after it had sat for several days…
Old, probably DOT 3 or 4 or 3/4 and the clear DOT 5 had separated. I'm guessing that is at least some of the reason not to mix grades of fluid, I suspect the synthetic components of the new style fluid prevent it from staying mixed.
Just thought it was interesting,
Chris
« Reply #10 on: June 16, 2014, 07:58:41 AM »
Interesting indeed!
« Reply #11 on: June 17, 2014, 06:36:05 AM »
I wonder if the reason has something to do with 3 and 4 being hygroscopic,  while the 5, which I think is silicon based, is not?
I wonder if it's the water and oil antipathy thing in action?
« Reply #12 on: June 17, 2014, 03:31:56 PM »
I think its more like Chris and brake fluid antipathy  Grin
« Reply #13 on: June 17, 2014, 06:32:54 PM »
Fwiw, I saw a urine sample yesterday that looked similarly.
mick750F
« Reply #14 on: June 17, 2014, 08:08:40 PM »
   Jeebers Ben, you said you wouldn't mention that to anyone.
   Chris, if you're mucking around with that MG in order to enjoy it why stop at 80% of the lines? Bite the bullet and replace them all so you know they're all good. After all it's really a four wheeled two seater bike...right? Seriously with all this old stuff we seem to like I like to bring important systems up to date whenever possible.
Cheers and beers...Melder
Pages: [1] 2
