August 21, 2017, 03:39:45 PM *
Author Topic: Turn Signal Relay  (Read 1353 times)
Robbo22
Jr. Member
« on: May 20, 2014, 10:10:40 AM »
By reading posts it looks like you guys have had a busy winter working on bikes.  I have had a busy spring and just got around to firing up and riding my 78F.
One problem.  The left turn signal is sluggish and the right does not work at all.  I think I may need a new relay.  Questions are - and they should be easy for you pro's - where is the relay located and where do I get a new one.
Thanks and I hope you are planning another trip to CT again this year.
Regards,
Rob
« Reply #1 on: May 20, 2014, 10:27:09 AM »
Hey Rob,
It should be located in a rubber hanging from the battery box.  For some reason i remember there being a second one, but that is probably crazy talk.  In terms if getting a replacement, the OEM ones are still available and $20 which is ridiculous.  I am positive you can get a replacement at NAPA for like $5, but i am not sure which one you need exactly.  I think Chris knows.
« Reply #2 on: May 20, 2014, 10:57:13 AM »
Hey Rob,
Why don't you make a trip to MA?  Cool
Any two prong relay would work better than stock. This one would be just fine - http://www.ebay.com/itm/2-Prong-Electronic-Turn-Signal-Flasher-Relay-EF32-Two-Pins-Round-25-Amps-/131186696636?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e8b5621bc&vxp=mtr
Regards,
Peter
« Reply #3 on: May 20, 2014, 01:53:30 PM »
Hey Rob,
Any Auto parts store carry these relays - yours is likely still the stock therma flasher (flashing rate depends on engine RPMs) whereas the newer ones are electronic flashers and depend on the battery. The 2-prong 12-V ones work just fine.
Good luck! And yes will see you in CT or MA this summer!
Robbo22
Jr. Member
« Reply #4 on: May 20, 2014, 02:54:24 PM »
Thanks!  You guys are a great resource.
Perhaps we can meet on neutral ground - say RI  Smiley
Rob
« Reply #5 on: May 21, 2014, 08:04:56 AM »
Since this is somewhat of a wiring topic, is " neutral ground" an intended pun?
If so Rob, you are a live wire!
Where would you recommend riding in RI?
« Reply #6 on: May 21, 2014, 08:08:49 AM »
But why would we go to an island??? Tongue
« Reply #7 on: May 21, 2014, 10:25:32 AM »
I hear Newport is nice in the summer
Robbo22
Jr. Member
« Reply #8 on: May 21, 2014, 10:48:48 AM »
Newport is nice but a bit crazy in the summer.  Perhaps one of the western RI rides - http://www.motorcycleroads.com/Routes/Rhode-Island_115.html
Somehow we could work lunch in here - http://www.wrightsfarm.com/restaurant/
Wrights Farm was recommended to me by a local rider.  His routine is Vanilla Bean for Breakfast, Wrights Farm for lunch.  He is a rather large fellow Smiley
Rob
BTW that was an inadvertent pun - I am not that clever.
« Reply #9 on: May 21, 2014, 06:26:01 PM »
Rob
Then to the nordiclodge.com for dinner…and have someone wheel you home on a cart.
« Reply #10 on: May 22, 2014, 09:37:59 AM »
That place looks awesome but ... "Adults - $91.00"   Shocked Shocked
« Reply #11 on: May 22, 2014, 07:09:26 PM »
honestly, I've only ever been there for lunch, that was $40 something, 8 or 10 years ago.
