September 25, 2017, 11:54:43 PM *
Author Topic: Wheel Spacers etc.  (Read 1559 times)
« on: November 24, 2009, 07:39:14 PM »
If anyone needs custom parts (like wheel spacers) made up, or if you'd just like to add another custom touch to your bike, shoot me a PM.
Costs are based on materials and complexity. I've got a bunch of steel and aluminum bar stock lying around.
-Alan
« Last Edit: November 28, 2009, 12:34:11 PM by Alan F. » Logged
« Reply #1 on: November 24, 2009, 10:36:22 PM »
I would like an extra long bolt that goes under the engine so I can fit case guards - thank you!
« Reply #2 on: November 24, 2009, 10:44:38 PM »
Do you mean #5 ?
« Reply #3 on: December 01, 2009, 10:18:37 AM »
Andy, would a 10mm x 13.1" (333mm) bolt work? Or longer still?
-Alan
« Reply #4 on: December 01, 2009, 10:22:48 AM »
Weekend Update:
I'll be making a batch of motor mount plates over the winter for the 750 as well as the 500/550/650 crowd.
-Alan
« Reply #5 on: December 01, 2009, 04:38:39 PM »
Yes Alan #5. Just needs to be 20 mm longer at either end.
Oooh motor mounts sound good - will the be shiny and be able to be polished? Wink
thanks Alan
« Reply #6 on: December 01, 2009, 07:12:35 PM »
I can't seem to find that bolt from my K3, would you be able to supply the length of the bolt? I do know the frame bosses are 12" so I guess 13.1" might fit.  I've found another bolt that's 13.5" but the price is much higher...
Mounts will be .185" cold rolled steel, a polished aluminum face plate is a fine idea, or would you just like to polish and clearcoat the steel?
-Alan
What else is discontinued that I could fab up?
« Last Edit: December 01, 2009, 08:11:13 PM by Alan F. » Logged
